MitchF150
Oct 11, 2013Nomad
Going to larger tires will only make your effective gear ratio higher (numerically lower) and actually bog you down compared to the OEM size.
As long as your OEM tires have the load capacity to handle the rear axle weight, you should be good as you are..
Mitch
Mitch
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
