losmt21
Oct 11, 2013Explorer
MitchF150 wrote:
Going to larger tires will only make your effective gear ratio higher (numerically lower) and actually bog you down compared to the OEM size.
As long as your OEM tires have the load capacity to handle the rear axle weight, you should be good as you are
Mitch
Okay that does make sure my tires do have the correct load capacity. So with that being said I will go with the same factory size tires. That helps a lot I prefer larger tires but having a fifthwheel changes that and no big deal it's worth the sacrifice . Steve
Thanks!!'
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
