twodownzero's avatar
twodownzero
Tires, what are you using? Trailer? Truck?
I just bought a used 5th wheel and I need to replace the tires. I'm not new to trailering but I know that trailer tires can really be a pain. I am used to using truck tires on trailers, however, LT235/85R16E tires won't have much cushion at max load for me; my trailer weighs about 9k pounds empty and has a GVWR of 13,500. It's a toy hauler and the empty pin weight is around 2,300 lbs.
Normally I'd go with an inexpensive, U.S.-made, E rated truck tire. I'm inclined to do that anyway, since they're rated for over 100 mph and I would not ever "overload" them although if I were to load my trailer to GVWR, they would be loaded to capacity.
Now I see there are trailer tires rated for 75 mph (Carlisle Radial Trail HD) that come in load range F, American-made trailer specific tires (Goodyear Endurance), and all steel construction tires in both Chinese brands (Tow-master, Sailun) and Michelin/Goodyear.
If money was no object, I'd be running the Michelin XPS Rib ($250) or Goodyear G614 ($320) tires. These are out of budget for my current setup.
Does anyone have any suggestions for a tire under $150? I'm inclined to stick to U.S. made, E-rated truck tires, but the F rated and G rated trailer tires that are made in China and rated for 75 mph, and especially the all steel ones, seem like something I should consider. Either way they will be replaced in 4-5 years, because they will age out before they wear out. I am religious about tire pressure, so it's really just a matter of wondering if I can trust a Chinese tire in 2019 and if not, I can probably live with a truck tire on my 5er.
I have searched and not much recent discussion on this topic; I'm trying to put some key words in my post here so that this thread may benefit others.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
