fighterpilota's avatar
Jun 10, 2013
Toad choice reconsidered
Had been considering small trucks but decided hauling 4 people was more important than hauling a deer. Besides can throw a deer in the back of the smaller vehicles that will seat 4. Now considering RAV4, Honda CR-V, Jeep, Suzuki Sidekick, and Toyota 4Runner to name a few. Want to tow on dolly because of need to tow a number of other different family vehicles. Don't know much about the named vehicles as to how many can be towed on rear wheels with out any big changes. Just release the brake, put 5 speed in neutral and go. Any opinions would be appreciated. Thanks
  • I flat tow 2 different vehicles. I have a NSA Ready brute towbar that has a built in surge brake. I went with this setup for the ease and low cost of towing multiple vehiclesor switching vehicles. A new brake cable, breakaway, and brackets run under $500. I use the magnetic lights.
    Toyota 4-Runner: I tow a 1995, Auto, 4x4. to do this I disconnect rear driveline. It is 8 14mm bolts. I can do it in about 10 minutes. I will say I am reluctant to do so in rain or snow but will cross that bridge when it comes. I do not know about towing a manual trans 4 runner.
    Jeep Wrangler: Bought a set of bolt on brackets for the winch bumper for under $100, new brake cable & breakaway for ready brute for under $200 and away we go. Much easier than the 4 runner but not as much cargo room. To offset some of the cargo issue I custom built a tire carrier and cargo rack system.
    Both of my vehicles can NOT be towed on a dolly. I am sure you will find most 4x4 or AWD(even worse) cannot. Even 4x4 with transfer case from mid 90's mostly do not have a neutral in the transfer case as the trend was to go electric engaging. Another thing to consitder is if the t-case is lubricated. Some lubricate only when the engine output is spinning.
  • Also, if you want to use a dolly then your limited to 2WD front wheel drive units only, that knocks out the AWD 4-Runner, Jeep, and Suzuki Sidekick.
  • If you looking for a 5 speed manual transmission you'll have to take the Honda CRV off your list. The CRV is only sold with an automatic transmission in the US.
Looking for advice before your next adventure? Look no further.25,128 PostsLatest Activity: Apr 24, 2025
