Thunder_Mountai's avatar
Thunder_Mountai
Explorer II
Feb 03, 2016
Toad higher or lower than RV and 5K or 10K capicty riser?
My Jeep toad is 5" higher than the new RV. The 5K riser is either 4" or 6" and the 10K is either a 3" or 7". I called Blue Ox and tech support said that they didn't care if the toad was an inch or two higher or lower as long as the differential didn't exceed 3". What is your opinion? Should I go one to two inches higher or lower?
My second conundrum is whether I need the 5K or 10K capacity riser. The GVWR of the Jeep is 5700 lbs. That is with passengers, cargo, etc. The gross weight of the vehicle appears to be 4800 lbs. empty. When towing the Jeep we have a bike rack and probably a couple hundred pounds of junk in the Jeep. So, we are probably right at 5K pounds. The difference between the 5K and 10K is about $30 and change. I'm leaning towards the 10K for a margin of safety.
Thanks in advance for your opinions and advise.
