Bobbo wrote:
cummins2014 wrote:
So is my compressor, but I still wonder  why you bother with the air, if you are using antifreeze. you certainly don't need to. I would think its either or.  I agree antifreeze is cheap, and just antifreeze works for many.
It just reduces the water dilution of the pink stuff. More peace of mind than practical. It doesn't cost anything more, and doesn't hurt anything. Personally, I just blow out the lines with air, then use pink stuff in the drains/toilet.
I never even bothered to blow the lines on a couple old travel trailers ,they had two low point drains, and I blew the water out of the traps with a leaf blower, and was  done. Never an issue. I took me longer to go get the leaf blower out of garage then anything.
Diluting the pink stuff ??  , at what 2.58 per gallon at Walmart ,I may use an extra gallon a year if thats the case , which is not keeping me awake at night . My way was brought  up to maybe save a bit of work . May I ask ,do you filter that air out of your compressor.
