2Ambros's avatar
2Ambros
toilet paper ....
So ... what is the consensus on tp? I have read several different things..... use 1 ply, use regular ole charmin, use rv tp. I know some people who do not flush any tp at all. Any advice on this important subject matter ? ;)
  • gbopp wrote:
    doxiemom11 wrote:
    We use anything that says septic safe. Always a 2 ply though. Lots of water and no problem in 3 yrs full time.
    And, lets not talk about the people that put used toilet paper in the trash can. :E
    Disgusting
    x2. Septic safe works for us.
  • I use the same as I did in my s&b before I was full time. Use lots of water and don't give it a second thought.
  • You could experiment with whatever you choose by putting some in a glass jar filled with water. Shake it a bit, if you want to simulate transport. Observe what happens to the TP.
  • We use anything that says septic safe. Always a 2 ply though. Lots of water and no problem in 3 yrs full time.
  • I like it soft, fluffy and a big wad.
    TP along with stuff gets flushed down a 3" line and then dumped out of a 3" line.
    Water & gravity carries the whole stuff down roughly a 3 foot drop into the tank.
    That is way more water then what carries the stuff down a 30-50 foot residential sloped line.
    Then when tank is full...water weight, gravity and sudden rush of the liquids carries the stuff down a 4-5 foot dump line.
    RVs are not complicated........K.I.S.S.
    Use what TP YOU like. I do! And have NEVER had a problem with TP, Poop Pyramid, Clogged Pipes or Odor.
  • Normal toilet paper don't even give it a thought. Well I don't at any rate been RVing for well over thirty years. Had every kind of toilet you can think of no problems with any of them.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
