yolo6886's avatar
yolo6886
Toilet/black water gurgling
hey folks, my wife and I live in our fifth wheel full time and we are noticing a problem. We typically dump our black water once a week on the same day, we've noticed recently towards the end of the week probably around day five or six whenever we flush the toilet we hear a gurgling sound. It sounds like it's directly under the toilet possibly reverberating up from the vent pipe which goes directly behind the toilet. we've never heard this noise before and the tank isn't even full. just curious if there are any suggestions and easy fixes for this, but mostly I just want to know what the heck it is! thanks for all the info!
  • That noise is a much better "dump time" signal than most of the wall indicators in our trailers.
  • If you are at a fixed base, check for a small bird starting to nest in the vent pipe. Or possibly a dirt dobber, I see you are in Florida. If anything stops the air from venting the pipe it will make a gurgling sound. I bought my MH in S. GA. and it had a dobber in the gas vent tube for the Refrigerator and I like to have never found the problem. .
  • Just a guess here, but maybe the vent pipe extends down into the tank too far and once the tank is nearing full it is unable to vent properly therefore gurgling. You might just use the gurgle as an indicator that it's time to dump rather than waiting.
  • Sounds like the noise that happens when the tank is full and the vent is blocked. I've heard of the vent pipe coming loose and dropping into the tank. This might cause that when not full
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
