bosworthj's avatar
bosworthj
Tongue Jack Issues
I have a Fun Finder 26RBSS that we purchased a couple of years ago. I am pretty sure it has a Lippert 285318 power tongue jack. About a year ago, I discovered that when it is already all the way up and you accidentally press the button the wrong way, you can overload it and blow the in-line fuse. Before I found the fuse and bought some extras I had to pull the small cap off the top and crank it by hand. Ever since then, it has been much louder than it used to be and seems to make more of a grinding noise. Finding a fix for that is my first issue. The second issue is, the unit takes a 30 AMP fuse. Is it possible to put a 40 AMP fuse in there to give a little more of a buffer for accidentally pressing the button the wrong way or would that most likely burn the motor out?
Thanks for any help!
Looking for advice before your next adventure? Look no further.25,193 PostsLatest Activity: Apr 10, 2026
