bosworthj's avatar
bosworthj
Tongue Jack Issues
I have a Fun Finder 26RBSS that we purchased a couple of years ago. I am pretty sure it has a Lippert 285318 power tongue jack. About a year ago, I discovered that when it is already all the way up and you accidentally press the button the wrong way, you can overload it and blow the in-line fuse. Before I found the fuse and bought some extras I had to pull the small cap off the top and crank it by hand. Ever since then, it has been much louder than it used to be and seems to make more of a grinding noise. Finding a fix for that is my first issue. The second issue is, the unit takes a 30 AMP fuse. Is it possible to put a 40 AMP fuse in there to give a little more of a buffer for accidentally pressing the button the wrong way or would that most likely burn the motor out?
Thanks for any help!
  • You need a 30A Time Delay (AKA slow-blow) fuse. They are commonly used with motors that have large surge current draw.
  • Unfortunately it is common to blow the fuse like that. The other caveat is to make sure you let the jack stop moving before switching directions. I would hitch the trailer up and then figure out how to disassemble inspect and grease the jack.
    And most importantly, always make sure your body especially your feet are clear of the trailer when using the jack in case it fails and falls. If it falls it will come down faster than you can react, as in it will be on the ground before you even realize it failed and fell. You don't want your body parts anywhere near that impact point.
    No on the 40 amp fuse, but you can replace the 30 amp with a 30 amp automatically resetting circuit breaker from the auto parts store.
    Link
  • no 40 amp fuse. The fuse is there to protect the wire from burning. Grease/oil the jack. Paint a line on the jack before it gets to the top.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 26, 2025
