BeerBrewer's avatar
BeerBrewer
Tongue Wt and Wt Distribution Question
We are new to RVing and I've got a question about my tongue wt and weight distribution.
We currently own a Grand Design Transcend 26RLS travel trailer, the sticker on the trailer says that the GVWR = 8495 lbs and the UVW = 6708 lbs.
My tow vehicle is a 2018 Ram 2500 CTD. My Payload is 2400 lbs, max tongue wt is 1800 lbs and max towing is 17,100 lbs. We are using a Hensley Arrow hitch with 1000 weight distribution bars.
Unfortunately I can't find an RV scale locally, so I bought a tongue weight scale, just so I'd at least know my tongue wt while I search for a scale. If I can't locate an RV scale soon I'm planning to unload the trailer and weigh everything one piece at a time and tally it up. The trailer is currently sitting in our yard all loaded up with our "camping stuff" minus food and our clothes. The kitchen cabinets basically sit over the trailer axles, so I don't think adding food will any increase the tongue wt at all. The clothes on the other hand are another story, since the bedroom is in the front of the trailer. So I took 4 storage bins of cloths, which is more cloths than we'd ever pack and put 2 of them in the storage bin under the bed and the put the other 2 on the bed but under the storage cabinets. Also, all of the tanks are empty, but these are all close to the axles. Then I weighed the tongue using my new scale and it weighed 950 lbs.
Is my 950 lb tongue weight too close the 1000 lb weight distribution bars? Should I go with the next larger size? The trailer seems to tow fine and the truck sits very level when hitched up, but I'm no expert. We don't experience any sway at all, even when passed by huge trucks on very windy days. When we do go over a bumb in the road the trailer does seem to push the truck up and down for a brief moment then steadies right out. Is this normal or does it mean that I need more weight distribution.
Thanks
Bob
  • If it’s porpoising try better shocks. It helped my truck that’s just like yours (even the colors are the same). It drivers better loaded and unloaded. The improved shocks also helped limit body roll when unloaded and cornering.
  • Congratulations!!! I think you're among the first to actually have a rig set up correctly asking if he had it set up correctly. Enjoy the ride, and see ya out there.
  • Awesome setup there beer brewer!
    Complete luxury towing! Did you ever figger out the driving on the parkways issue?
