oyarsa
Nov 09, 2017Explorer
Tongue weight with weight distribution hitch...
Before heading out on our first trip with our TT, we took a trip to the scales. Here are the numbers.
With everything hooked up:
Steer axle - 3420 lbs
Drive axle - 3780 lbs
Trailer axle - 4840 lbs
Total - 12040 lbs
Just the Toyota S equoia and everyone in:
Steer axle - 3340
Drive axle - 3380
Total - 6720
Our axles are indivually fine. The GCWR is great. If I'm right, the trailer is 5320 lbs, which is well under its GVWR. The Toyota is 7200 lbs when connected. That is 100 lbs under the GVWR for the TV.
What concerns me is the tongue weight. It appears to be 480 lbs. Compared to the 5320 of the trailer, that's only 9%. I don't really have any weight I can shift to the front of the trailer. I suppose I could put water in the fresh water tank that is ahead of the axle. Even if I add 100 lbs (staying within the GVWR of the TV and GCWR), that still is just 10.9%
Suggestions? The trailer seemed to do ok, but this being my first trailer, I have nothing to compare it to...
Total - 12040 lbs
Steer axle - 3340
Drive axle - 3380
Total - 6720
