TNRIVERSIDE's avatar
TNRIVERSIDE
Too cold for my refrigerator??????
I am new to having a RV style refrigerator. While reading my owner manual (yes, I'm one of those that actually read the manuals) for my Norcold N61X I notices a section titled "Effects of Freezing Temperatures on Refrigerator Operation". It states that below 32 exposure may disrupt the operation. It states the the operation will resume when the temperatures warms. So if the outside temps stay below 32 it sounds like the refrigerators inside temp will rise. Has anyone experienced this?
  • Only problem we have had is if the temp in coach is below 32 degrees, it will not cool the freezer. Found out that to fix, just open refrig, and turn heat on in coach. When refrig gets above 32, it works fine.
  • camperpaul wrote:
    If the temperature inside your RV is below 32°F (0°C), the thermostat in the refrigerator will never call for cooling.
    If you are heating the inside of your RV and want to use the 'fridge, you will need to heat the compartment behind it.
    I use a Thermocube® and a 60 Watt lamp and block off 2/3 of the louvers on the access panel; I'm good to -20°F (-29°) O.A.T.
    Great idea. Don't thnk I will be in my MH at -20 though.:B As a practical matter though most RV parks are closed when you need the heat behind the fridge. I don't run my gererator all night.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    we regularly wintertime camp where it gets into the "teens" at night and in the mid 30's in the daytime and I've never noticed the fridge not doing it's job. Keep the trailer at 68-70 in the daytime and set the thermostat for 45F at night.
    Haven't had any need to heat the outside fridge access area.
  • you can buy a thermostat plug in at the farm store I think it turns on at 40 and off at 50 we use it for the heat lamp for our goats.
  • Ivylog's avatar
    Ivylog
    Explorer III
    I block off the vent with cardboard on the inside when it's cold. Have not had to add heat, but if it's really cold you may have to.
    Thanks Paul
    I had never heard anything about this before. I have read post about cold weather camping but the Refrigerator issue was not discussed.
  • I have a Dometic in my MH but also had a Norcold in my previous TT. I haven't noticed any problems as low as 5 degrees F. I keep the inside of the RV at 70 because I'm a sissy:B I didn't read all of my manual. I do winterize at 10 degrees even if on the road. I have a outside mounted thermometer on my Dometic. It runs about 35 to 38 degrees. I like cold beer.
  • If the temperature inside your RV is below 32°F (0°C), the thermostat in the refrigerator will never call for cooling.
