noonenosthis1's avatar
Apr 02, 2019
torque for shank bolts
Hi all,
I've gone from an Excursion to an F350 for towing. The F350 is taller than the Ex so I've turned my hitch upside down and now I need to retorque the shank bolts. What is the correct torque for those bolts?
Thanks
  • Reese states 300 ft-lbs on their installation instructions. If you don't have 300 ft-lb torque wrench the instructions also state 150 ft-lbs and then another 1/4 turn so that is what I did. That other 1/4 turn is a real pain even with a 3 foot breaker bar.
  • jfkmk wrote:
    TBammer wrote:
    Get the biggest breaker bar you can find for the socket that fits the bolt. Then get a 4 foot length of cheater pipe to go over the breaker bar. Then have your biggest/strongest friend lean on it until he can't lean no more. But my last reading was like 300-400 ft/lbs.
    Or you can take it some place where they actually use a torque wrench.
    Yeah, or you can do that, which is prolly the best move.
  • Scientifically, as tight as I can get with a 1/2 drive ratchet or my air impact on middle setting. Couple hundred ft lbs.
  • asme spec. 250 lb./ft for 3/4" nc gr. 5 dry bolt in that application. Torque is not an issue as much as shear load because the bolt is not so much a connection as it is subjected to side shear load. Lubes reduce torque spec. depending on type. Machine oil to moly paste, makes a big difference. Moly can reduce torque by 50 %
  • Standard is by ball shank dia, but best to check your ball's OEM specification
    https://www.etrailer.com/question-109595.html
    Curt recommends the use of 250 ft/lbs of torque when tightening the nuts of their hitch balls with a 1 inch diameter shank like the part # C40034 that you referenced.
    The general rule is for a 3/4" shank tighten to 150 ft/lbs For a 1" shank tighten to 250 ft/lbs, and for a 1-1/4 inch shank 450 ft/lbs.
    Ops...reread the OP's comments...guess it is the WD hitch head bolts...use the OEM's spec
  • Get the biggest breaker bar you can find for the socket that fits the bolt. Then get a 4 foot length of cheater pipe to go over the breaker bar. Then have your biggest/strongest friend lean on it until he can't lean no more. But my last reading was like 300-400 ft/lbs.
  • 832.42729 somethings.
    Ok, probably not.
    Why not ask the manufacturer of the hitch?
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 09, 2025
