FLHTCI's avatar
FLHTCI
Tow bar options & instillation advice
First I want to thank everyone for all the good advice you’ve given me so far. As a new class A motor home owner, I’ve learned a lot from your advice.
I’m now embarking on outfitting my 2013 Jeep JKU to be towed behind my RV. The previous owner sold me his Brake Buddy. I’ll just need to but the breakaway switch and install it.
What tow bar do you recommend and should I have it setup professionally? Looking at the side that attaches to the Jeep seems straight forward.
Thank you
  • Normally I would recommend the ready brute elite tow bars as they have an integrated mechanical brake so there is no separate braking system and nothing to fail. Once it's set up there is no installing/uninstalling the supplemental braking system. But since you already bought a supplemental brake before buying bars or base plates, I can't be of much help in that category.
    We used Blue ox base plates on our CRV when we towed it and they were easy to install and will work fine with a variety of bars. If you aren't fairly adept at DYI and have the proper tools you may want to take this to a shop. It was about 4 hours labor so expect estimates accordingly.
    There is no set up for the bars per se. They simply go into your MH receiver and hook to the clevis' on the baseplates on your vehicle.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 25, 2026
