Leo3150's avatar
Leo3150
Tow Dolly or 4 wheels down Tribute
I put a message earlier this month about towing a 2011 Mazda Tribute and the perils of such a practice. The transmission went out about 60 miles east of Amarillo, TX at a rest area. Had it towed to the Mazda dealer in Amarillo. Mazda is going to pay for a new transmission and the labor involved. UPS lost the first transmission according to the dealer. Sent the dealer the pages that showed how to tow the Tribute with 4-wheels down. Put in neutral, ignition in the 2nd slot, and stop around 200 miles to run the engine and put transmission in all gears for a few seconds. Now Mazda says not to tow the Tribute that way any more just like Ford says for the Escape. Mazda suggests using a dolly or putting in the lube pump. Hopefully this information helps someone out that is towing a Tribute.
My question in all of this is which is the preferred way and the easiest way of towing now. Should I get the Remco lube package for the transmission or the dolly. With the lube package I know that I will have to stop about every 200 miles to cool the transmission fluid and also to recharge the battery for the auxiliary brake. My spouse is leaning toward the dolly because the transmission could go out again if something happens to the lube package. I can see her point, but I am worried about the car coming off of the dolly (or am I being unreasonable)from some of the discussions on RV.Net under towing. I have looked up the Roadmaster dollies. Is the inexpensive one (if you call $1600 inexpensive) okay or should I go with the top of the line if I go the dolly route.
Any tips, sage advice is appreciated.
Thank you,
Leo
  • I have a master tow dolly and love it. Takes about 10 minutes from start to finish to hookup or unhook. Safety chains and heavy adjustable front tire straps hold the car securely. Whatever brand dolly you pick, make sure it has brakes either elect or surge
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
