Not enough information and see the OP using UVW...AKA Dry weights, which
are sales tool level of information.
Comments in red embedded below and decide if you believe in the OEM
ratings system or not.
If not, then this discussion academic and just go with whatever...but
know that the OEM(s) are now off the warranty (if any left) hook and
liability hook (no end date)
If yes, then learn how the ratings system(s) work. Note that 'R' in
all of the acronyms...means 'rating' and there are conditions for
each and all ratings.
The generic ratings formula is:
GCWR => TV + Trailer + hitch + everything loaded on/in the setup
Then the 'can do it' vs 'should' or 'rated' to do it...which is VERY
subjective...I'll not drive lots and lots of setups out there and many,
many think I'm overly conservative...but that is my value system and
why my advice is always to the OEM's ratings system for those asking
to make up their own minds.
plasticmaster wrote:
Mt truck has a tow capacity of 9700#.
Out of context...the 9,700 MTWR (max tow weight rating).
In context would be using the actual weight of the TV, as MTWR's are
generally derived from 'curb' weight TV's...AKA stripper model TVs
in reference to the TV's OEM ratings
If your TV is loaded up with options, cargo, people, pets...etc...there
is no payload rating left for the WD Hitch, tongue, etc...so the
MTWR is ZERO
My current travel trailer has UVW of 5500#. When loaded with all our stuff my truck pulls it very well.
For the lowest class TV...the next higher class, or the next higher
class?
Meaning your TV has loads of margin in it's ratings vs actual
Im thinking of upgrading to a TT with UVW of 6900#. Obviously, I would load the same "stuff" in it. How well would my truck pull it? The new camper has a GVWR of 9500#, so the numbers look like it's within capacity.
Goes back to not enough info and the above comments in red...is the
current TV at the hairy edge of it's ratings...over it's ratings...or
with plenty of ratings left?
Am I right?
