mowermech's avatar
mowermech
towbar recommendations
In the near future I may be setting a Dodge Ram 1500 up for towing. It will be extended cab, short box, probably 360 V8, 4x4, auto tranny, 2001 or earlier. It will replace the "toy truck" in my sig., which will be sold (I hope).
I will be looking for a simple, trouble free, minimal maintenance, relatively inexpensive towbar, minimum 6000 lb. capacity, not more than 8000 lb.
what brand/model will meet those specs, if any?
  • If you want a good value for the $ towbar check out DEMCO, no fancy hype just value for your dollar.
  • Roadmaster, IMO, makes the strongest base plate setup for any truck. Also, their Falcon 2 A/T is rated at 6K, but when I talked to their tech team in Q, they said it was tested Waaaay higher than 6K and they would have no qualms towing over the rated weight, within reason. That is my setup. Their next step up is the Blackhawk A/T, which is rated a 10K. I bought a Roadmaster grill guard directly from Roadmaster, which mounts directly on the base plates when not towing, so it looks clean even with the brackets still installed.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 15, 2025
