jimbo4UT's avatar
jimbo4UT
Tow/haul mode
What to do? I was on a steep grade and tapped my brake and it downshifted from 3 to 2 and hit 6000 rpm. I still wanted to slow down more but could not hit the brake again as I was high on rpm already in second so I took it out of tow mode and hit the brakes hard then put it back into tow mode. Was that correct? What would have happened if I hit the brake in tow/haul mode from second to first gear with no room for more engine rpm?
Jim
  • What tow vehicle? Is it diesel or gas? What kind of load are you towing? Give us something to go on, here...
    I my case going down a steep grade, with a diesel and a six-speed transmission, I put the transmission in "Manual" mode and select the gear I want. I can then tap the brakes as needed to supplement the engine brake.
    Rob
  • “but could not hit the brake again as I was high on rpm already” What?
    Leave in tow/haul mode. Don’t overthink. Use your brakes as required...slow way down, release brakes to cool, repeat. Read an article on downhill driving.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
