- mowermechExplorer
Tom/Barb wrote:
mowermech wrote:
I have also been told that the steering wheel lock can be disabled on those Jeeps so equipped. I hear it is a very simple procedure, so there is no reason to keep disconnecting the battery.
I have completed this switch procedure, and the key can be left in the off position with the steering unlocked.
BUT
The wheels may lock back up when your front wheels pass thru the centered position and stay in that position while being towed.
Yes I have placed my Jeep on stands and tried it. it does lock.
If the lock pin is removed (the recommended procedure), the steering wheel can not lock.
Or, just buy a 2006 unit or a 2012 or later unit, and have no problem. - Tom_BarbExplorer
BUT
Yes I have placed my Jeep on stands and tried it. it does lock. - mowermechExplorer
Tom/Barb wrote:
chuckftboy wrote:
Mowermech is correct, there are no fuses to pull, just turn the key to unlock the stearing. You can leave the key in tht position without fear of draining the battery
Not so my 07. (JK) any position of the key will turn on the electrical, and the normal (on) is the only position that unlocks the steering.
I must place the key in the ON position and disconnect the battery.
Yes, as I understand it that is TRUE for 2007 and later.
That is why I specified "2006 and earlier".
That is also one reason why I would never buy a 2007 or later Jeep Wrangler for a toad.
I have also heard that sometime in 2009 Jeep quit using steering wheel locks, so there is no longer any problem about switch position.
I have also been told that the steering wheel lock can be disabled on those Jeeps so equipped. I hear it is a very simple procedure, so there is no reason to keep disconnecting the battery. - Tom_BarbExplorer
I must place the key in the ON position and disconnect the battery. - RaymonExplorer
chuckftboy wrote:
I tow a 2006 Wrangler setup just like Raymon, even use the Demco towbar, very easy. Ran a set of wires and added 2 additional bulbs to the tail lights, Mowermech is correct, there are no fuses to pull, just turn the key to unlock the stearing. You can leave the key in tht position without fear of draining the battery
X2 Exactly. After many miles towing, I never once had the battery to discharge while towing. - JohnnyTExplorer IIMoved from class A forum
- 2bzy2cExplorer II
mowermech wrote:
"if you DONT disable the ignition you'll run the battery down (while towing)."
Not true on a 2005! 2006 and prior Jeeps had an "OFF, not locked" position in the ignition switch. THAT is the position the switch has to be in while towing (as noted in the Owners Manual).
I towed a 2006 Wrangler Rubicon Unlimited many miles with the switch in the "OFF, not locked" position.
Since my son's 2003 Rubicon has that type switch, I'm fairly sure the 2005 does as well.
My 2000 Wrangler had the off position as well. No need to pull fuses. - bshpilotExplorer
good ! thanks for the correction.
after mid 2009 (iirc) they (once again) did away w/ the need to keep a key in the ignition, when they removed the steering wheel lock. - chuckftboyExplorerI tow a 2006 Wrangler setup just like Raymon, even use the Demco towbar, very easy. Ran a set of wires and added 2 additional bulbs to the tail lights, Mowermech is correct, there are no fuses to pull, just turn the key to unlock the stearing. You can leave the key in tht position without fear of draining the battery
- Tom_BarbExplorertow bar and brake system from E-Bay, and wiring harness from Cool tech is all you need.harness stuff
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
