MrRules
Aug 20, 2016Explorer
The manual does indicate that the vehicle may be towed with all four wheels on the ground. It also suggests that certain fuses be removed, to keep the battery from draining, but they are not in the battery compartment as the manual indicates. The Batt 1 and OnStar fuses are both in the fuse box under the hood on the passenger side. I understand there is a way to add a switch that would allow you to just flip the switch to take these fuses off line instead of having to pull them each time you travel. This is really what I am trying to find.
Stu
Stu
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
