kodiakcanuck's avatar
kodiakcanuck
Towing 5th wheel near the trucks limits
Without starting up the great "can halfton's tow 5th wheels" debate, what are your thoughts on how the truck would handle this tow:
5th Wheel Trailer
2005 Flagstaff 8524 CBS
25 feet
Pin/hitch weight 1010 lbs
Gross Weight 8115 lbs
Dry weight 5866 lbs
Truck
2014 Ram 1500 4x4 crewcab, 5.7 VB 3:92 rear end
Max towing 10,000 lbs
Max Payload 1450 lbs
The max payload weight would be close, so nothing else could be added in the truck. Mostly just driver and passenger in the truck.
I have towed a 29 foot travel trailer that had a heavy 800 lbs hitch weight and a good weight distribution set up and it still felt comfortable, so although this 5th wheel would have a heavy set up on the payload, the trailer would be shorter than I have previously towed.
  • MFL wrote:
    Not recommending...but from experience, towing overloaded with a FW, is a better experience than towing overloaded with a TT.
    Jerry
    ^^This^^
    Over or not bet it still tows real nice
  • kodiakcanuck wrote:
    Thanks for the info all, I think I have decided against this set up.
    If that fifth wheel was a Travel Trailer you'd be fine. Just saying - you can tow a lot bigger TT with any given truck than a 5th wheel.
  • Kodiak, I've never met 'Old Biscuit," but I think he is probably one of the most knowledgeable on this forum. Consider his response.
    Remember, this RV thing is supposed to be fun, and fun always costs a lot.
    MFL wrote:
    Agree with Old-Biscuit, it will work if you can stay under rawr/tire rating. You will likely be over payload some, but 2014 truck won't break in half over a few hundred lbs.
    Jerry
    The tires are L/T BF Goodrich All Terrain KO2, so they have a higher rating than stock tires. I will check it out, Thanks!
    JFI for your next truck or trailer....your trucks rawr is the lessor of a tire....wheel....rear suspension....axle rating.
    Up rate one component is fine but don't forget the others.
    Lol, fake news.
