TimbBerWolf
Aug 25, 2018Explorer
Older Tow Truck
Hello
Long time lurker and decided to join to ask for some help.
I have a 2006 Ford F150 larite 4X4 supercab 5.4 eng with a 3.73 rear end. I currently have 89,000 miles. Payload capacity is 1485.
I have had this truck since it was new and have always maintained it. In fact in preparation of towing with it I added an increase transmission oil pan capacity along with an exterior transmission cooler. I also added an increased oil capacity cover on the differential with a drain plug. I changed the oils in both the transmission and rear end to synthetic. I also run "E" rated tires.
Problem
I currently have a 2011 Heartland Caliber 265RLS with a GVWR of 8600 (lb) which I feel is too heavy for my truck I don't like towing it. I run a Reese WDH. I feel like the trailer is pushing the truck around.
Solution ??
buy a new 3/4 ton truck really don't want to spend $40K - $50K on a truck. (although deep down I really love to have a new truck :) )
OR
Purchase a lighter trailer for say $30K and keep our truck we like the Grand Design 2250RK GVWR 6995 (lb).
Question
Is the Grand Design 2250RK the right trailer? I know math wise it should be no problem. I'm also aware some people will always say a 3/4 ton would be much better.
What say YOU all?
What if anything should I do to my current truck tow this weight if anything.
Problem
Solution ??
OR
Question
What say YOU all?
