valhalla360
Nov 30, 2015Navigator
As others have said:
- Was the lift done professionally and to the same standard as the original? You might have lost signficant payload and pulling capability.
- The real trick is getting the 5th wheel to tow level. The newere 4x4's already sit much higher and often require the trailer axles to be flipped. If they are already flipped, you may have to add frame extensions and then the trailer get really high off the ground.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
