BlackJeep22's avatar
BlackJeep22
Towing a 2008 2dr Jeep Wrangler
First time motorhome owner. We just purchased a 2016 Coachman Concord 300DS (Class C), 32'.
Eventually, we will be towing my (manual transmission) Wrangler.
1)Can anyone recommend a good towbar?
2)Am I required to have the tail lights and break lights hooked up on the Wrangler?
Thanks in advance.
  • sch911 wrote:
    You also need a toad braking system in most places....
    Almost, but not quite true. Many states do not have a legal requirement for brakes on a towed motor vehicle. However, many states (and the Federal Motor Vehicle Safety Standards) have Braking Performance Laws. You must be able to stop your combination of vehicles in a certain distance (usually 40 or 45 feet) from a certain speed (usually 20 MPH) when on a level, clean, hard surface (like a paved parking lot).
    As for what towbar to use, ANY towbar will do the job! I towed an assortment of Jeeps for many years with a simple fixed arm adjustable width towbar by Reese (I think it was a Reese..). Anyway, I see a similar bar at Walmart for $165. It did the job very nicely.
    You can get a very good telescoping towbar with integrated braking system from NSA/Ready Brute that will work very well on your Jeep. The braking system is a surge type, with no electronics at all. Simple and effective. It will cost around $1000 for the full setup.
    Check out the Ready Brute website for more information.
    Disclaimer: I do not own one, nor do I have any affiliation with the company.
    For a long time I used a set of Harbor Freight magnetic mount lights for towing.
  • You also need a toad braking system in most places....
  • Daughter tows a 2007 Wrangler 4 down using a Blue Ox Tow bar and base plate with Blue Ox Auto Stop. You will need tail and brake lights operable on the Jeep. Easy to do. Easy to install a connector to your Jeep which, when connected to the connector at the rear of your MH will illuminate the tail and brake lights when applied. You will also need safety chains (cables) and a brake away brake.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
