Hank85713
Aug 03, 2014Explorer
I have towed my motorcycles all over on a home built single axle trailer without brakes and never had an issue. Initially we got it used and after a time made some upgrades. Had a spring hanger break in Louisiana got to shreveport and took to a shop where the guy was actually a blacksmith. He redid the hangers and never had another problem. Also added some shocks to control axle jump. I ran car tires and they held up well, just dont let them get too old. Your gw is only 900 lbs so if you get too much trailer/springs you will not have enough weight to actually load the springs and it will bounce on ya. Just like trailer pulled behind mc's. Some have 2 leafs and they bounce as they are set up for more weight than is carried. I took 1 leaf out of mine and it was much better. Most trailers do not require brakes until they have a gw of 3000lbs in most states, some may be 1500 but all depends on where it is licensed. Just some thought to consider
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
