- Grit_dogTrailblazer
whemme wrote:
That 1 ton pickup probably weighs at least 6000 lbs. Why do you want to tow something so dam heavy?
I'm guessing it's because he can. Towing an 8000 lb toad with a 42' diesel pusher is much easier than towing the combination in your signature. If I had a big diesel pusher I wouldn't hesitate to rig up my F250 diesel with an air actuated braking system and 10K tow bar and tow it.- notevenExplorer III
Diesel 350/3500’s weigh 8000 to 8500 lbs empty. - notevenExplorer IIIRicB - I would check on the type of disconnects used in class 8 trucks.
I saw a Duramax dually with a motorcycle lift on the rear flatbed set up as a flat tow. The owner had a brake system connect actuated by the motorhome’s air brakes. It was a nice set up. - whemmeExplorer IIThat 1 ton pickup probably weighs at least 6000 lbs. Why do you want to tow something so dam heavy?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
