moisheh's avatar
moisheh
Towing a Rav 4 Auto Trans
Of course we all know that Toyota never recommends towing one of their vehicles with an Auto Trans. My wife has a cherry 2001 Rav with 80,000 km. I was considering a Remco lube pump. I was glancing through her owner's manual and there was a chapter on Dinghy towing. One paragraph explains how to tow this vehicle behind a MH. Simple. Put it in neutral and turn the key to ACC. DONE!!Limited to 250 miles and then just stop and run for 3 minutes. I think it was also 55 mph.max. Being a doubter I called Toyota to verify. Yes my manual is correct. I asked if they were sure. Response was that if the manual says it is OK then it is OK. Yet a 2002 cannot be towed even though it is the same model transmission. I wonder why the discrepancy? Could it be that they approved but had some problems with the transmissions? Or did Corporate just decide it was a bad idea? I called Remco and they had no record of the car being towable. I am goiung to order a baseplate later this summer and try it in the fall. Could be a $2000 mistake?
Moisheh
  • I think you both misunderstood my post. I do not need a pump. My manual states that it can be towed behind a MH with no pump required!
    Moisheh
  • Have 2003 Rav4 installed Remco pump as soon as we got it. There were 2 diff Trans. used similar models diff part# diff dates of mfg. I worked Toyota Dealership parts ~ I called Toyota research, gave them Vin# & bunch of other info & they verified my Rav4 OK for pump. So with Toyota's Ok got Remco to install pump.
    The little guy has followed a '89 Catalina ClassC or 2007 Sunova 26P Class A ever since. No trans problems. Still our daily driver when not being a 'Toad'
    ~~~ JM2¢ ~~~ YMMV
  • I installed a Remco pump on our 2002 RAV4 and towed it trouble free for about 30,000 miles. Then I moved the pump to our then new 2011 RAV4 and have towed that one for another 20,000 miles, all with no mileage limits or special prep besides turning on the pump control at the coach dashboard. Oh, and the 2002 is still pretty much trouble free serving as a our spare car that we leave at our upstate NY vacation cottage.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 29, 2025
