bhooperdoski's avatar
bhooperdoski
Towing a RAV4
We bought a 1998 RAV4 to tow behind our motor home. I have just installed the Roadmaster towing brackets and today I started looking at wiring for the rear lights. First, because the blinkers are separate light bulbs, this makes it more complicated, but besides that the wires are all enclosed to where you can't get to them like you can in older vehicles where all the wires are attached to the frame.
That said, I'm looking for some help. I would like to know what's the easiest way to setup the wiring for towing the RAV4 behind a motor home. Any help will be greatly appreciated.
Thanks in advance.
  • The wiring kit you linked to is intended for hooking up a trailer to your RAV, and will not work the other way around. The 4 lights to 2 lights adapter will not work in reverse unless it's different from the one I have for my utility trailer that's towed by my 2002 RAV4. When I wired our RAV's for towing 4-down, I connected the diodes to the rear light wiring at the driver's side front lick panel. It took a bit of hunting and testing with my meter to find the correct wires, but they're all there. I chose to fully wire the lights so the RAV's lights work exactly the same as the separate brake and directional lights on our coach. When we bought our current 2011 RAV4, i did exactly the same installation again. It saved running wires all the way to the back.
  • $23.00 at Wal-Mart magnetic towing lights with 4 pin hook up keeps it simple
  • Yes, I'm positive. It's a 1998 AWD RAV4 with a manual transmission and I have the Toyota Towing Supplement that says there's no problem towing it.
    Also, I think I found out the best way to go on the wiring. I just need to verify it's okay, but I'm sure it is and they have a video showing how to get access to the wiring.
    Thanks
    Here's the link if anyone is interested.
    http://www.etrailer.com/tv-wiring-install-2001-toyota-rav4-2.aspx
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
