- lanerdExplorer IIJust asking...no disrespect intended. I've read here that NO Toyota has been towable 4-down in many, many years.
Ron - Vulcan_RiderExplorer
lanerd wrote:
Vulcan Rider wrote:
Ask Toyota.
Some models require special consideration and others just need to be in neutral.
Are you suggesting that maybe the Sienna can be towed 4-down without modifications?
Ron
Is that what I said ??
No. I don't know.
ASK TOYOTA. Do I need to somehow phrase that differently ?? - lanerdExplorer II
Vulcan Rider wrote:
campingman55 wrote:
Ok can I tow a 2012 toyato seinna 4 down while running or do I need a lube pump and have it turned off and I don't like tow dolly
Ask Toyota.
Ron - dan-nickieExplorerConsider if you have a toad braking system, the toads power brake pump will be running therefore the brakes may lock up when activated,
Ask Toyota.
Some models require special consideration and others just need to be in neutral. - naturistNomad III, too, would worry about problems arising that you wouldn't know about until major damage had already happened. So, certainly possible, but generally bad idea.
- Bird_FreakExplorer III would be concerned about air flow across the radiator for cooling.
- ValkyriebushExplorer III had the remco lube pump on my Mercury Villager front wheel drive automatic that worked perfectly. I'd go that route.
- BumpyroadExplorerMy boss once left his car idling for 8 hours in the parking garage and no issue. I can't see why idling behind a motorhome would be that big a deal. obviously you need some indication that it is still running.
bumpy - RoadpilotExplorerHad a friend that bought a lube pump that was one of the first for that vehicle. It kept dying. They towed the car for a long time with the engine running while the company tried to get a fix for the pump. The pump ws finally fixed. The car was an Escalade. I would worry about the engine stopping, but it never did.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
