simple274's avatar
simple274
Towing a Silverado
Hi
I have a 2014 Silverado that I would like to pull it behind my MH.
Those of you that pull one or know how to wire the lights on one would sure be appreciated, or a wire diagram, or where to get one.
Thank You
  • anyone know of a plug and play wiring harness for the Silverado? just got a 2017 1500 and we would like to set it up to be towed with our Class A. I currently have a Jeep Wrangler and I was able to find a plug and play harness for that but not much luck with the Silverado
  • I took our '11 GMC 1500 Extended Cab 4x4 to the scales right after we got it and, with a full tank of fuel, it was right at 5300 lbs. The Dinghy Towing Guide claimed it weighed 4875. That's not the first time I've proved them a bit off.
    Scott
  • A 4x4 extended cab Silverado weighs at least 6000 lbs.!!!!. Mine has a cap and is even heavier
    Moisheh
  • j-d's avatar
    j-d
    Explorer II
    The lighting is one thing, and the suggestions above are good.
    But I must ask: Have you confirmed that this specific Silverado is four down towable? I found the Owner's Manual and dug down to Page 10-94 where it said the 2WD can't be towed four down and "See Dealer" for 4WD models.
    What coach will you tow the truck with? Silverado is pretty heavy, even a 1500. CAN you tow it with a Class C? Sure, but I can tell you you'll feel it. Most gas coaches, you'll feel it. Most diesels, not so much.
  • simple274 wrote:
    Hi
    Thank You
    simple274,
    Tying into the factory wiring causes some to run for the hills. It's not very complicated at all. I've done it on 11 different toads in about 35 years of towing. When done properly, you don't have to drill into any housings, add any light bulbs, drape wires all over your nice paint (causing scratches and scuff marks) etc. I use two Radio Shack diodes and that's it, period!
    We tow an '11 GMC Sierra 1500 4x4 extended cab which, it darn near identical to your intended truck. Now, as stated, I did the wire our Sierra using that method but, on our other toad, a '15 Jeep JKUR, I used a system simalar to the one linked above. It's nice to use a plug and play system like that. If the one linked will work for you, then I'd highly suggest that.
    Once you're done, YOU'RE DONE. No putting lights on and off EVERY SINGLE TIME YOU TOW. I do have a wiring diagram of this simple system if you'd like to PM me. Good luck.
    Scott
  • This is what i used on my 2015 GMC
    https://www.etrailer.com/Tow-Bar-Wiring/Chevrolet/Silverado+1500/2016/HM55999.html?vehicleid=20161363731
  • I thought about something like that, but I seen people pull like I want to and just wanted to know how they did it.
  • Our dealer was very emphatic about voiding the electrical portion of our warranty if we spliced into the factory wiring harness, so we went with a wireless magnetic system and love it. set the lights on top of the bed, plug in the transmitter to the RV and away we go. The batteries last over a year of normal towing. Great system.
  • The_real_wild1 wrote:
    Easiest way is to run a set of magnetic tail lights.
    yep, $9.95 at harbor freight.
    when I towed a pickup it had a cap and I just permanently mounted tail lights on the cap that plugged into the lead from MH.
    bumpy
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 24, 2026
