- goducks10ExplorerHow would the weight cut down on mpg? If you are getting say 10 mpg and another person weighing 200lbs rides in the truck, do you really see a drop in mpg? What like .1-.2mpg? I have never really noticed any loss of mpg when adding a little weight to anything I drive. If I put four 50lb bags of mulch in the truck I still get the same mpg. Only loss of mpg by adding a cap on the ruck would be from the lack of the vortex created by not having the tailgate on. Not from 200lbs for the cap.
- Airstreamer67ExplorerI think it does help some, but the real advantage is all that extra protected storage in the back.
My campertop rises to within a couple of feet as high as the top of my trailer, and on the back of the campertop I installed a wing which helps divert air over the trailer.
I average 14 mpg towing a 27-foot Jayco trailer with a Ford F250 diesel, which puts it in an excellent economy category for a rig this size. - bikendanExplorerits weight would negate any savings on cutting wind resistance.
- VintageRacerExplorerBased on experience, yes it helps a little but not much. Cuts down sway as much as anything. Significant drag actually comes from the tall flat rear end of the trailer.
Brian - downtheroadExplorerMay cut down a little wind resistance...but adds weight so it's pretty much a wash as far as mileage improvement.
- BumpyroadExplorerthere have been conflicting reports on this. so I guess the answer was "maybe"?
bumpy
