gamma3116's avatar
gamma3116
towing a5er and getting a lot of teeter totter down the road
I would like to know how to slow down this teeter totter action I get while going down the road. It gets bad at times were the t.v. speakers will come loose from the cabinets. Any suggestions ?
  • I'm guessing you are talking about a porpoise condition? Hitch height is the problem. When hooked up and on level ground, the 5er should be a little nose high. Not level and not down hill. Not too high either!
  • Not sure what you mean by "teeter totter". Are you talking side to side, or front to back? I got mine to quit bucking by lowering the front of the trailer. Don't go overboard and get the trailer too near the bed of the truck though.
  • Do your trailer axles have shock absorbers? Some manufactures do not include them - or put them on one axle, not both. Many times they are worn out, and not that good of quality.
    Is your hitch mounted with the center 1" forward of the center of the truck axle? If mounted behind the axle, it can cause bad handling on the truck and possibly trailer problems as well.
    How much weight is on the hitch? Check the truck front and rear axle weights, then hitch up and check the truck again, then the whole rig, and let us know what you found. Also let us know if the water tank was 1/2 or 1/4 or full.
    Most fifth wheels are pretty stable, so suprised to hear this.
    Good luck,
    Fred.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 23, 2025
