scolson's avatar
scolson
Towing capacity
I'm looking to purchase either a 5th wheeler or travel trailer and I'm not sure what the towing capacity is of my truck. Here are the specs for my truck. Thanks.
Vehicle Name Ford F-150
Body Style Crew Cab
Drivetrain Four Wheel Drive
Gross Axle Wt Rating - Front 3900 lbs
Gross Axle Wt Rating - Rear 3850 lbs
Curb Weight - Front 3214 lbs
Curb Weight - Rear 2372 lbs
Gross Vehicle Weight Rating Cap 7350 lbs
Gross Combined Wt Rating 13500 lbs
Dead Weight Hitch - Max Trailer Wt. 7700 lbs
Dead Weight Hitch - Max Tongue Wt. 770 lbs
Wt Distributing Hitch - Max Trailer Wt. 7700 lbs
Wt Distributing Hitch - Max Tongue Wt. 1155 lbs
Fifth Wheel Hitch - Max Trailer Wt. 7700 lbs
Maximum Trailering Capacity 7700 lbs
Engine Type Regular Unleaded V-8
Displacement 5.0 L/302
Trans Type 6
Trans Description Cont. Automatic w/OD
Spring Capacity - Front 3900 lbs
Spring Capacity - Rear 3850 lbs
Axle Type - Front Independent
Axle Type - Rear Rigid Axle
Axle Capacity - Front 4050 lbs
Axle Capacity - Rear 4100 lbs
Axle Ratio 3.55
Front Tire Capacity 4050 lbs
Rear Tire Capacity 4050 lbs
Wheelbase 145 in
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
