scolson's avatar
scolson
Towing capacity
I'm looking to purchase either a 5th wheeler or travel trailer and I'm not sure what the towing capacity is of my truck. Here are the specs for my truck. Thanks.
Vehicle Name Ford F-150
Body Style Crew Cab
Drivetrain Four Wheel Drive
Gross Axle Wt Rating - Front 3900 lbs
Gross Axle Wt Rating - Rear 3850 lbs
Curb Weight - Front 3214 lbs
Curb Weight - Rear 2372 lbs
Gross Vehicle Weight Rating Cap 7350 lbs
Gross Combined Wt Rating 13500 lbs
Dead Weight Hitch - Max Trailer Wt. 7700 lbs
Dead Weight Hitch - Max Tongue Wt. 770 lbs
Wt Distributing Hitch - Max Trailer Wt. 7700 lbs
Wt Distributing Hitch - Max Tongue Wt. 1155 lbs
Fifth Wheel Hitch - Max Trailer Wt. 7700 lbs
Maximum Trailering Capacity 7700 lbs
Engine Type Regular Unleaded V-8
Displacement 5.0 L/302
Trans Type 6
Trans Description Cont. Automatic w/OD
Spring Capacity - Front 3900 lbs
Spring Capacity - Rear 3850 lbs
Axle Type - Front Independent
Axle Type - Rear Rigid Axle
Axle Capacity - Front 4050 lbs
Axle Capacity - Rear 4100 lbs
Axle Ratio 3.55
Front Tire Capacity 4050 lbs
Rear Tire Capacity 4050 lbs
Wheelbase 145 in
  • There's a recent long thread on 1/2t and FW towing; search for it. Yes, some smaller FWs can be towed with the right 1/2t (donn0128 is incorrect; he is correct about p-rated tires). Yes, you have to be very careful to not overload the FW. Your problem is the 5.0 motor and 3.55 axle that are very limiting. I towed an 8,400lb FW for years with an '04 F150, 5.4 and 3.73 axle. No problems on the flats but I never went mountain climbing.
  • Someone said it would only be 1400# pin weight on the truck. Go put 1400# of sand in it and see what you get. I don't think you will like the handling.
  • Keep your search to travel trailers, and keep your search to those under 7000 GVWR and you will be OK. You might be able to up that a bit, you the higher you go the less happy you will be.
    Remember, your towing rating was originally based on a base level truck with 1/4 tank of gas and a 150 pound driver.
  • That leads back to my original question. Given the truck I have what would be the max gvwr of a 5th wheel or travel trailer I should be looking at.
  • GVWR would likely be around 9k lbs for 7k dry trailer. That's pushing it for a travel trailer with a heavy equipped half ton, and isn't doable as a fifth wheel. You live in Oregon so mountains are going to be part of your towing experience, so keep that in mind too.
  • The 7000 would be shipping weight which I guess is dry weight.
  • scolson wrote:
    Say the 5th wheel is 7000 lbs and the rear tires are rated at 4050 lbs max. The 20% is only 1400 lbs.
    what number is the 7000lbs.?
    GVWR or UVW(unloaded yellow/white sticker weight) or fictional website/brochure dry weight?
  • Say the 5th wheel is 7000 lbs and the rear tires are rated at 4050 lbs max. The 20% is only 1400 lbs.
  • Read my lips.... no fifth wheels with a f150/1500 series truck. Unless it is 20 feet or less long. Its not a matter of towing, but rather a matter of loading. A typical fifth wheel will load approx 20% of its loaded weight directly over the trucks rear axle. 1500 type trucks tend to have P metric tires with very low load carrying capacity.
    To prove my point, load your truck up like your going to go camping and drive across a set of scales. Subtract your scaled weight from the GVWR as posted on your drivers door post.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
