jffnkrn's avatar
jffnkrn
towing fifth wheel plus little trailer
not sure if this is in the right place. I am contemplating adding a small trailer to my fun. Plan is or might be: We have fifth wheel, want to add a lifted golf cart of some sort. About 1000 lbs with trailer. So just looking for thoughts and ease of towing. some have added boats, quad trailers etc behind fifth wheel. Your thoughts, comments, constructive criticism is welcome. thanks in advance, Good Luck & Be Safe ! ! !
  • OP - you make no mention of what kind of fifth wheel and tow vehicle you have. Besides the legalities, you need to consider whether or not the frame on your fifth wheel will handle it and whether or not you will exceed the combined gross weight of the truck/trailer combo, etc.
    Rob
  • I've done this many times, works well for me. Second trailer tracks well behind FW. Keep in mind, it is nearly impossible to back two trailers, other than a short distance.
    There are varying state laws. You may want to check your towing areas.
    Jerry
  • RoyB's avatar
    RoyB
    Explorer II
    Check out the IDAHO TOTE DOLLY brand extension platform that is not considered a trailer. It is physically attached the rear of the fifth wheel and has two swivel wheels to the ground for support...
    google image
    google image
    Even this may not be legal in all States... Check with your licensed state DMV to see what the status might be for you...
    Roy Ken
  • Limited! Not legal in most states, and some require additional licensing of the driver.
