l70cam
Sep 26, 2017Explorer
Truck Towing and Trailer Compatability
Hello, I'm about to pull the trigger on a used camper, specifically a
Travel Trailer, 2010 Rockwood Signature Ultra Lite 8317SS. I currently have a 2017 GMC Sierra 1/2 Ton Pickup with the following data:
4x4 double cab regular box w/tow package
5.3L w/3.42 gear
Max Tow Weight: 9400lb (according to GM directly based on my VIN)
Wight of truck: approx 5500lb
GVWR: 7200lb
GCWR: 15,000lb
Trailer data is the following:
UVW: 6595
Tongue Weight: 975
GVWR: 8617
I have done all of the math and with the weight of the truck, passengers, cargo within the truck, weight of the camper and cargo within the camper I fall under the vehicle GCWR by about 800lb. What I'm really worried about is the tongue weight of the camper and how well the 1/2 ton pickup I have will handle this trailer. Currently I have a weight distribution system that I have from a previously owned camper that I had which is a Curt 17002 with Gross Trailer Weight(GTW) 10,000 LB & Tongue Weight(TW) 1,000 LB.
http://www.curtmfg.com/part/17002
I also have an added on sway control arm that mounts to only one side of the trailer tongue and hitch assembly.
I hope I can get some good input from others that may have had experiences with similar equipment. My 1st thought is that maybe I need to buy a much better weight distribution system or a lighter camper. Getting a larger vehicle just isn't currently an option.
Thanks in advance for any input that you may have.
Leon
5.3L w/3.42 gear
GVWR: 7200lb
GCWR: 15,000lb
UVW: 6595
Tongue Weight: 975
GVWR: 8617
Leon
