rk911
Nov 25, 2022Explorer
Wsm239 wrote:
Hello. I am not new to towing 4 down but we are considering towing our 2020 Jeep Grand Cherokee 4 down with our Thor Hurricane 34B with the Ford V10.
Obviously the hitch is rated for 5,000lbs but the Jeep weighs around that amount too. We would be using a supplemental braking system. I am sure the coach can physically tow the vehicle but is it wise to go this close to the limit? A few years ago we towed a Chevy Cobalt so never had to worry about it.
Are there other considerations/limitations - insurance for example?
first, be certain that the hitch is rated at 5K.
the amount of weight you can safely tow will be the lesser of the following:
- The difference between the loaded weight of the MH and GCWR
- The weight rating of the hitch
- The weight rating of the towbar
IMO, I would NOT tow the GC even assuming all of the above will permit you to. The advice I received back in '03 when we started to tow was to never tow at the max limit and instead tow at no more than 90% of max. You could likely push that to 95% and be OK.
And depending on options your GC may come in at >5000-lbs. have you weighed it lately configured the way you would tow it? (stuff loaded in the back, X-gallons of gas, etc.) Don't trust the owner's manual or the sales critter for the curb weight.
good travels whatever you decide to do.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
