azdutchie's avatar
azdutchie
do you FLAT TOW your WL Grand Cherokee?????
do you have a WL Jeep Grand Cherokee Overland, Summit or Summit Reserve? Are you flat towing this vehicle? please let us know if you also have tracking issues....
My 2023 Grand Cherokee L Summit showed good tracking the 1st 5 minutes after putting the vehicle in flat-tow mode correctly behind my DP.
Herewith my findings from 4 hrs of testing last Friday morning:
• No matter what setting of the computer, the car will track less after about 7-8 minutes and completely stop tracking the tow vehicle after 15 minutes. The steering does not react at all at any speed and the towing vehicle simply drags the towed Jeep front tires through the turn.
• If you put the steering mode into SPORT, the diminished tracking starts in about 4 minutes, in NORMAL the tracking gets worse after 6 minutes and in COMFORT it lasts the longest, about 8-9 minutes. After each failed test I would go to the vehicle and without changing any setting, the steering wheel moved freely back and forth, as would be expected.
• I have entered the vehicle into flat tow mode according to the handbook procedure every time, with the doors closed. After the flat towing setting is clearly accepted, I put the key FOB in a Faraday pouch, so that it does not transmit anything to the vehicle. I enter my motorhome, the tow vehicle, and started driving the parking lot at Home Depot on Hunt Highway. Big parking lot to the north.
• I have tried each setting for a minimum of 20 minutes at parking lot speeds, ranging from crawling to maximum 5 mph. On various occasions I have driven into new paved neighborhoods with speeds up to 25 mph and on SR 24 with speeds up to 65mph. The result are basically the same every time: the vehicle stops tracking/steering/following the tow vehicle after 15 to max 18 minutes, but performing ok after every new startup.
• I have tried restarting the flat towing process at least 20 times and going back to factory standards after each try. I have varied ride height settings, steering mode settings, but I have always clicked every possible brake and/or detection settings off (that is accident prevention, pedestrian detection, anything and everything)
All in all it is my uneducated opinion that something is wrong with the steering system (EMS?). If I didn’t know any better, it seems as if some part of the system is losing pressure. If there are any oil or air cylinders as part of the steering, it seems that this loses pressure, as the tracking capability is losing abilities gradually. Sometimes it even seemed as the steering tires turned/jumped straight, when the tow vehicle started to straighten out the turn.
We are trying to find other Jeep owners with similar issues. So far the dealership has no idea what to do about it. We have found another 45 other owners.
PLEASE contact us when you have issues as described above!
Thanks
Johan de Keizer
  • There is a good towing instruction sheet with some things I didn't think of here:
    https://www.irv2.com/threads/grand-cherokee-summit-reliability-and-towing-concerns.2189544/#post-23693267
  • My new to me 2025 JGC WL Overland is also not tracking. Have an apt with dealer. I can turn the wheel while sitting in tow mode but once towing is underway, the wheels don’t turn. Fob is far away.  Doors are not locked. I towed a 2008 JGC and it was so easy. This thing is just too complicated and sensitive. Sensors go off easily if towing in rougher roads or even highways. Lights go on.  Then they go away after a while of driving. Wish I could get parts for the 2008 but it has become unreliable at that ripe old age also.
  • I let them win.  I sold mine.  Back to a Dealer,  HAHA,  Will never  own another Jeep. I have been buying Jeeps since 1985.  That one was my last. Jeep does not stand behind their products. All they can say is " Engineers are working on the situation". Never get back to you on Star Reports.  PS:  Star Reports are close after 2 weeks, a Service Manger told me. You have to keep filing them.
  • Did you ever get this flat towing problem resolved. My 2025 is doing the same.
    • azdutchie2's avatar
      azdutchie2
      No, I did not. I just taking for granted as I tried to measure tire wear from Seattle to Phoenix and was not measurable...
      Here or there I try same question, but never get an answer. We do have other electrical gremlins such as fuel pump running (this is only a guess ) till battery is empty. Had that 2x. Mirror folded in while locked, will not come out after starting and Drive. Simple restart resolved that issue. And various other small issues that are not repeatable and not show up on computer check.
      • Hikergal321's avatar
        Hikergal321
        Explorer II
        Just following up for any updates.  My 2025 JGC Overland will not track behind tow. I am following manual and adding extras like turning off lane assist, fob in faraday pouch, waiting up to 20 minutes for system to go to sleep.   Steering wheel can be turned and wheels turn that way but towing they don’t turn or track behind.
  • I have a 2022 Grand Cherokee Summit. In the last 3 weeks, I have towed it for about 3500 miles with no problems. Except for hitting a piece of debris and flatting two tires. My TPMS saved us.
    Rich
  • There was a lot of information and problems posted associated with EPS. For earlier years Jeep developed a harness kit that kept EPS on while towing for earlier models than yours.
    Strongly suggest you go to the iRV2 forum and see what you can find...:h
  • I could not find the article, but I remember an article saying electric steering vehicles cannot be towed with front wheels on the ground.
