Bruce1963's avatar
Bruce1963
Towing in 3rd gear on a 1300 mile trip
I have a 1997 GMC k1500 Z71 5.7 liter with 20000 miles and a 4L60e transmission with only 2000 miles, I will be towing a 3000# dry weight TT from Louisiana to Colorado. I plan on breaking the trip into 2 1/2 days of travel, question is will it be OK to travel for 10 hours or so at 2500/3000 rpm in 3rd gear towing around 3500#? Will it be too much of a strain on my engine/transmission?
  • I would not tow all the time in third gear. If it starts searching you can pull it down to third or just push the throttle a little and make it down shift. But unless it is running at low rpm or struggling I would let it go to forth.
  • That's correct, the 60e is known to have weak OD gears. With the weight you're looking at it probably doesn't matter. Run whatever gear takes the least throttle.
    Frontal area / wind drag will always be more a factor than weight with travel trailers.
  • Everything I have read says to not tow in overdrive, 4L60e is a 4 speed tansmmssion. It runs great the truck is in tip top shape, I just don't want it to hunt for gears, I want to find the sweet spot and that seems to be in 3rd gear going 60-65.
  • Sounds like your transmission is done. If it won't go in 4 gear your tranny might blow
    No but it might be a strain on your safety......if that results in going too much below the posted speed limit.
    IF.....the transmission will shift into high gear/lock up and STAY there, you are much better off letting it DO that.
    Downshifting when/if necessary is MUCH preferred to staying in a lower gear because the transmission will heat more that way.
  • Why do you want to tow a light trailer in 3rd gear? A 1997 with 20,000 miles?
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
