RV4funtimes
Mar 16, 2020Explorer
Thank you all for your suggestions. We will try the hitch to see about the play. However, it is the MH that has front end wandering. It is similar to overloading the bed of a pickup and the front tires are not making good contact with the roadway causing the front end to bounce and wander. Our MH has a 138” WB and is 22’ in length with approximately 7’ of overhang behind the back axle. I have read about the ratio of WB to length. The tech person who wrote the article said it should be at least .55 to tow. Ours is only .52. The front axle weight is only about 3000 lbs while the rear is almost 7000 lbs unloaded. We have towed vehicles behind a 28’ MH with longer WB and a 22’ Sprinter van with a longer WB and no problems. Same tow bar setup. Any other ideas would be greatly appreciated.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
