lldolls's avatar
lldolls
Towing our 28’ Jayco
We have a 2009 Ford F-150 XLT SuperCab, we purchased a 28’ 2016 Jayco Jayflight BHBE. The tow weight on our truck is 9800lb and the camper weight is 6540. The truck came with 235 70R 17 passenger tires. We went to purchase new tires and they recommended a LT tire. They put on a size 265 70 R 17 Wrangler Adventure AT with Kevlar. We tried pulling our camper for a short trip and it was porpoisng (bouncing up and down) so bad we couldn’t hardly stand it! We have asked around to try and find out what to do about it and Ford told us that it is because we have the wrong size tire for our truck. They said an all terrain tire is too “meaty” for our truck. Goodyear told us the same thing but the tire store says it is not the tire. Please help if you have had this issue and found a resolution.
  • When my truck was new, with new tires, it was really squirrelly pulling our 37ft TT. After about 1k miles on the tires everything settled down.
  • While the taller tire could hurt tow capacity. It shouldn't make the truck bounce. I would look more at the WDH. to me. It sounds like it is not tight enough / not pulling enough weight, Letting the truck, and trailer tongue bounce on the springs. Pull another link or so in the chains, and see if it calms down.
  • The taller sidewall and deeper tread can cause the ride to become squirrelly. It may improve a bit with time. Did you air the tires to the max pressure? That will help with the sidewall flex.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
