HittinSteel's avatar
HittinSteel
"Towing" Question
Hello everyone. My family and I have been lifetime campers. We recently sold our 20' hybrid TT and will be upgrading to a much larger unit. We really like the Jay Flight 32RLDS for our needs.
This TT has a dry weight of around 8,000lbs and a tongue weight of close to 1,000 lbs.
My truck is a 2001 Dodge Ram 1500 with a 5.9, tow package and beefed up sport edition. I think it can handle around 7,200 for towing and 1,000 tongue weight with a WD hitch.
We plan to have the TT delivered to our campground and then go permanent for the foreseeable future.
My question is will my truck be capable of moving the trailer INSIDE the campground if necessary? I hate the idea of not being able to move (or re-situate) the camper to a new site or to the storage area at the campground.
My thoughts although well over weight for road driving, I would be fine for this limited use. Thanks.
  • In your case I would move it with your P/Up. I used to move our 28 ft TT from the front yard to the back yard with my 4 cy Toyota P/Up. Never had a problem.
    I never used WDH either.
  • Thanks for the responses...... I just wanted to confirm my thinking. I will be sure to watch the tongue weight closely (remove everything from inside the front of the camper and maybe even the tanks/battery etc.) before moving it.
    The campground will move campers for a small fee, I just hate the idea of not being able to do it myself if I need/want to.
    The truck is pretty stout as I routinely load the bed with unseasoned hardwood during my winter firewood gathering. It does very well with just a little "squatting".
    Down the road if we decide to do any real towing I'll upgrade to a 3/4 or 1 ton.
  • I would still use a WDH for moving between sites. I moved my camper before without a WDH and the steering was REAL LIGHT!
  • Agree with LarryJM above.
    5 mph inside a campground to change sites....I'd do it.
    Since your talking very short moves not involving public highways I think you will be fine. If you find your tongue wt. is way above your receiver's limit then you could always take off the propane bottles and battery and even put them temporarily in the back of the trailer secured for the short move inside the CG. I would probably even forgo using any WDH since at the distances and speeds even overloading the receiver by say 2X should be O.K.
    As an alternative a lot of CGs have small tractors that can move TTs within the CG and you could pay to have that done also or even hire someone with a tractor to come and move the TT for you for probably less than a couple of hundred $$s.
    Larry
