coolmom42
Jan 26, 2017Explorer II
camp-n-family wrote:
I towed with an '03 V6 and an '04 V8 4Runner. Started with a 10' pup then a 19' 3600lbs hybrid. Finished with a 26' 5k bunkhouse with the V8. They were good reliable tow vehicles that towed well, within their rated capacities. The 26'er was getting a bit long for the short wheelbase 4Runner though.
I don't have experience with the new generation T4R but it has basically the same 4.0l engine as the older model. A little more power now and mated to a tranny with more gears should make it better than what I had.
The only note I can add is that the stock T4R hitch is not rated, or recommended, to be used with a WD hitch. It is simply bolted to the rear cross member which isn't designed for the stress. If you want to use a WD hitch you should get a frame mounted hitch.
The 2016 4Runner brochure refers to the "integrated towing receiver hitch." Wonder if that means it's been changed to frame mounted? All versions are listed with 5000 lb towing capacity.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
