FSAD's avatar
FSAD
Towing with E rated tires, that DON'T go to 80psi
I'm looking to get different tires soon and while I have been happy with my Hankooks (I'm on my 3rd set, albeit I only get about 25k out of them), I want to go a little bigger, and it seems all the E rated tires that have an 80psi max do not have the larger sizes.
My question is to those of you who tow with a larger tire that while being E rated, only has a max pressure of 65 (typically what I'm finding in the larger ones). I know the load rating is there in the specs, but I worry about them not being as solid as a true E, 80psi, one. Are they solid? Do you get any more sway (I, have an 8500# bumper pull), or are they "squishier"?
thanks for your input
mikey
ps, I wanna stick with 17"s since the wife will kill me if I start talking new rims
  • rhagfo's avatar
    rhagfo
    Explorer III
    This may not be the answer you are looking for, but due to the rating of my 265/75-16E's (3,415#) I only run them at about 65 to 70 psi when towing, as I only have about 5,550# of weight on the rear axle when towing my 5er, tires look fine and feel solid.
  • Sorry, My bad, That is the only size Nitto makes that uses 80psi. The other sizes use 65psi
    http://www.nittotire.com/light-truck-tires/terra-grappler-all-terrain-light-truck-tire/
  • There ARE tires out there that are E rated (have the load capacity), but only go to 65psi, for example:
    Duratrac in 325/65/18, E, 65 psi, 3860 lbs
    Terra Grappler G2 in 305/70/17, E, 65 psi, 3195 lbs
    Firestone Destination AT in 315/70/17, E, 65 psi, 3195 lbs
    Firestone Destination MT (same)
    My main concern is the squishiness; HOW WELL DO THEY TOW?
    thanks
  • Thanks, but I'm looking for info from folks who have tires with max LESS than 80 (typically 65 for an E rated one)
  • I put a set of Nitto Terra Grapplers on my Ram 2500, They have a load index of 126 which equates to a load range of 3750lbs at 80 psi (as opposed to the load index of 121 on most E rated tires). I was very happy with the towing performance, and they are made in the USA. I had to go to the 285 size though.
