trnfla wrote:
Golden_HVAC wrote:
Hi,
One problem with letting a engine idle for a long time (like the 2 hour drive) is the quantity of oil going up to the valve train. It is just not as much lubrication as a engine running 2,000 RPM or so. But the oil pressure is fine, just the gallons per hour going up to the top end is less than normal.
Fred.
I do stop at least once an hour, so I could run the transmission through the gears and rev up the engine.
Also, does anyone know if my odometer will log the miles?
Can't you tell??? wright the mileage down before you leave then check it when you arrive.
Bill
