Bedlam
Mar 30, 2016Moderator
I was addressing ACZL in the same post I addressed yours. You can see the same type of unloading and porpoising when you have a heavy bumper pull without WD - The weight is less, but there is more leverage when it is sitting over 4' behind the axle. Even truck campers with their CG right over the rear axle can unload the front by a couple hundred pounds, but the porpoising is typically not there unless the springs or shocks are too weak for the load.
