labren's avatar
labren
Towing with slider in extended position?
Looking at alternatives to an auto slider. Do any of you tow your 5th with a manual slider locked in the extended position, to allow for enough clearance for no contact to the cab, and at the same time it eliminates the need to jump out of truck when you need to turn sharp?
I have a friend that drives with his slider hitch in the extended position all the time, to give him more room at the front of the box.
Your comments on this would be great!
  • I will drive around the block or park with the hitch in the extended position, but not down the road. It only takes about 30 seconds to switch it.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
