Off_Pavement
Aug 07, 2017Explorer II
Your 2017 Wrangler doesn't need a key to unlock the steering as there is no steering lock.
I use a battery charge line from the 7 pin RV connector fused 12V pin on our RV, wired through a 20amp circuit breaker directly to my Wranglers battery. You can see the battery charge line in the following diagram from my supplemental brake system installation guide...
UTB Install Diagram
UTB Install Diagram
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
