Lyrikz's avatar
Lyrikz
Toy hauler door hinge replacement.
I dont know if this is the best place to post this but i need some help. I opened my toy hauler door to far and i bent a couple of the hinges. How do you slide these off????
Here is a picture. I know how to support the door and what not, but im just wondering if the end caps just pop off or what. Thanks.
  • fred42 wrote:
    This appears to be the standard Lippert ramp door like I have. I found that the end caps are pressed on and not removable while the hinge is installed. Fortunately, the aluminum hinge rod is not connected to the end caps as you might expect on one end. Get a Torx T55 socket bit for a socket ratchet wrench and remove the three hinge bolts. With the door closed, it will be fine temporarily with one less hinge. You may have to tap the hinge off, I don't recall.
    Door parts can be ordered at the Lippert store:
    https://store.lci1.com/products/cargo-entry-door-parts?___store=english&p=2
    6 of mine are bent. lol. SO i will have to supprt the door and go from there. Thanks for your info.. I ordered them.
  • This appears to be the standard Lippert ramp door like I have. I found that the end caps are pressed on and not removable while the hinge is installed. Fortunately, the aluminum hinge rod is not connected to the end caps as you might expect on one end. Get a Torx T55 socket bit for a socket ratchet wrench and remove the three hinge bolts. With the door closed, it will be fine temporarily with one less hinge. You may have to tap the hinge off, I don't recall.
  • This would probably be better suited in the toy hauler section. Ask the moderator to move it for you.
    With the slight bend I see in the pictures, I would just hammer them back straight.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
